Default logbook [IN DISCCUSION]
It would be nice if we could set a default logbook instead of having to select it each time. Or, have I overlooked that option?
@NO4D Hey Ken,
No you haven’t overlooked it, your meaning like set a specific logbook as a default and then when you click ‘log contacts’ it goes straight into that logbook thats set as default vs having a list?
Yes, with maybe a drop down menu if we want to use another log. Make sense? Not a biggie either way.
Good idea. Small change but definitely a good QOL feature. Everytime you leave the logbook to look at other information, such as the Leaderboards, you have to reselect the same logbook. Perhaps it could be an additional selection in the Action column of the logbook list.
-Jack
I guess I want the default AND the list. :man_shrugging:t2::zany_face:
@NO4D I’ve added to our list of possible features to discuss. :wink:
Hey Brad…for some reason I can’t download my Everyday log file. It says it’s getting it ready to export, but nothing happens. My other logs export with no problem.
Ken/NO4D
@NO4D Hey Ken,
Interesting, yeah i just tried it on your account and it says it will notify me when its ready to be downloaded but never actually downloads. I’ll reach out to the team and have them take a look for you. I suspect its because there are a large amount of QSO’s in there. I’ll reach back out asap.
@NO4D Hey Ken,
You should be all set now. Let me know if you are still having trouble.
All good! Thanks!
Ken
When I go above 200 contacts in map I get this…
@NO4D Hey Ken,
As opposed to? Its doing that to show all the contacts within the window.
Why are they all pointing to a single location in another country? Under 200 it show them only from y QTH. Trying to make sense of that.
My QTH is SC.
@NO4D which one of your logbooks is this? the ‘NO4D-Everyday’?
Yes…Everyday
@NO4D I’m going to reach out to the team on this one, it almost looks like either some of your contacts have the wrong lat/lon or your location isn’t set (however i can see you do indeed have a location set in your logbook settings for this logbook). What’s even more odd is you have a QRZ subscription and QRZ call sign lookup enabled which is where the lat/lon is getting pulled from. I can see this being an issues IF you didn’t have a QRZ subscription and had QRZ callsign lookup enabled but that’s not the case. Like I said I’ll reach out to the team and have them take a look for you and I’ll reach out after we’ve dug into this a bit. Thanks for the heads up!
Thanks. I may be the only one with this issue. :face_with_peeking_eye::wink:
I can delete log and start from scratch. I have a full log in N3FJP I can import. No problem if that’s what’s needed.
@NO4D ok thats very good to know. i do think somehow its linked to incorrect location….somehow. we’ll dig into it and i’ll reach back out as soon as we’ve had a chance to dig into it a bit.
