Send QSO to Different Log
Would like the ability to log a QSO and immediately send to another logbook. I keep a general log and it would be nice to be in that log and make a contest QSO that I could send to the contest logs I keep.
@N3VD Hey Good Morning Tess,
Thats possible however that would be duplicating QSO’s and throw off the analytics so i’m not entirely sure we would want to do that. I’ll still at least reach out to the team and have a discussion about it.
Can I throw in what I do, which really best applies to logging with a computer. I open two browser windows for logging sometimes. For instance I keep a general log and right now I have a 13 colonies log. Then I can just bounce between the two windows.
Nice workaround to solve the problem! :100: :+1:
But I suggest to find a better solution. :smiling_face_with_sunglasses:
I propose the following:
Feature Request @K4AZE
Assume the following situation:
I have an open logbook and I am logging contacts.
My feature request is,
to have in the “window” where I log contacts a pulldown menu with all my logbooks (Sorting order: Last used on top). When I choose another logbook, I will be moved immediately to that logbook.
The benefit is,
that I don’t have to open three browsers, when I am logging this week all 13-colonies-stations in my 13-colonies-logbook, all POTA-contacts in my POTA-hunting-logbook and all other contacts in my “normal” logbook.
73 Pepe
I like this solution!
I have the same request - I now accidentally logged into my general log and wanted to move the qso to a log i keep for a net. No can do which is a bt sad - so lukcily it was just one qso - otherwise i woudl have had to export and import and delete which seems unfriendly. Surely if logs are move you can quitely reavalute scores and stats in the background when the servers have doan time
Right now I dont care about that - I am simpy using WRL as a general online log
@ZS1PIG You can use the QSO manager in the web app to select QSO’s and move them to other logbooks.
