I often switch between logbooks while playing radio. I have a couple different programs that push qso’s to WRL via the WSJT-x listener. I usually will create a new logbook to activate. I often forget to change the target logbook. So I have to go into the QSO manager and move the QSO’s.
It would be a great to have the target logbook change to the logbook you switched to in the logging app/screens.
Unfortunately there isn’t really a way to do that and even if we could figure out a way to do that, that could cause lots of issues for other users that are switching between logbooks that don’t want those qso’s to into the ‘active’ logbook they are in at the moment.
We have a major update to the UDP streaming coming in the next few days that will allow you to setup multiple UDP streams (into various logbooks if you’d like). This will most likely solve this issue for you.
