QSO Manager, moving QSO's from one log to another
Created a new logbook for an activation after the fact. Used QSO Manager to move the QSO’s from a previous logbook. Everything moved over fine except the map shows’ that I was in New York rather then my actual location. What did I do wrong so it doesn’t happen again?
@KI4QXQ After you’ve created your logbook just make sure you’ve set your logbook location either via a saved location or a custom location. You can update your previous qso’s with the correct location by using the QSO manager and bulk editing
the details.
