Moving QSO from one log to another
Hello, I was trying to move a QSO from one log to another and was able to do it from the app but not on the web. Is this a bug or am i doing something wrong? When I edit it and save it on the web, the change doesn’t stick.
@KF0KVM On the web app you use the QSO Manager. Then you select the QSO you want to move and click the ‘move to logbook’ button.
Thanks! Is there a way to batch edit my location? Say, I made 20 contacts but had the wrong location and want to move them all at once to the correct QTH.
@KF0KVM Yes, use the QSO Manager and select the QSO’s you want to edit (you can filter by logbook using the Filter button). Then click the ‘bulk edit details’ button. Then select the ‘location’ button in the quick settings bar above the logging fields and either select a custom location or select a saved location from the drop down.
Here is a quick screen recording:
Hope this helps!
