Create a map from different logbooks
I would like to create/view a map of contacts made during the ARRL DX contest. Right now the contacts are in 2 different logbooks. Is there a way to move them into 1, dedicated, logbook so I can generate a map from just the contest? Thank you!
@K5JZZ Hey Steve,
Yes, you can use the QSO Manager (‘Logbooks’ → ‘QSO Manager’) and then you can filter by logbook using the filter button and then select the contact you want to move then click the ‘Move to logbook’ button to select the logbook you want to move those QSO’s into.
Then once the QSO’s are all in one logbook you can either go into that logbook and click the map tab, or you can goto the ‘QSO Map’ (‘Logbooks’ → ‘QSO Map’) and then filter by logbook again.
Brad K4AZE.
Perfect. Thank you!
