Is there a way to add a contest log to my everyday log instead of having to export and import?
Hey @NO4D! I’m gonna try my best to answer this!
What I assume you are asking is to take your logs from the ARRL Digital Contest logbook that WRL creates for you, and move (not copy) them into your main logbook. This can all be done in the QSO Manager.
Start by going to “Log Contacts”, and selecting “QSO Manager” at the top
Once you are there, click on the “Filter” button, and select “Logbook”
Then select your ARRL Digital Contest Logbook and hit “Apply”
Now it is showing only your QSOs from that logbook. You’re gonna select “Select All”, and then it should show you that all of your QSOs are selected
Then you just use the “Move to Logbook” button, which will bring up this menu
And then after you select the logbook you want to move them to, I ASSUME it should move everything over safely, but I have not tested this feature before so I can only guess that it works as intended. (I would still export your log file as a backup just incase)
I hope this answered what your question!
Daniel W2DIY
Thank you. I’ll make sure I have a copy before doing so.
Ken
Perfect answer - thanks for the help!
