DX Spotpage
I would like to make a suggestion of adding DX Spotpage. It would be a nice addition to this APP.
Maybe this isn’t exactly what you are wanting, but if you are in a log, then on the right hand side of the page is the Log/Map/Spotting/Stats section. If you click on Spotting, then you will see DX Spots, but you will need to check the W3LPL Cluster or the W7JD Cluster to see non-SOTA/POTA spots. It would be nice to be able to add other spotting sources.
73, Jim - KK7A
Thanks Jim I’m new to this app and still trying to figure it out.
