Export a QSO?
If I export a single QSO, should it automatically log in QRZ?
@W1SCD Hey Shaun,
Are you meaning if you log a contact in WRL should it automatically log in QRZ? Yes, if you goto the integrations page in the web app and enable QRZ import/export. To do this you’ll need your QRZ API key from your QRZ logbook settings and in the WRL Integrations page you’ll enter the API key and then select the WRL logbook from the drop down that you want the QSO’s your logging to be exported from. Alternatively you can goto the QSO Manager and select a QSO (or multiple) and click the ‘Export to QRZ.COM’ button and it will export those QSO’s to your QRZ logbook (as long as you have the integration setup as mentioned previously).
I hope this helps.
Great thank you. I should have looked further. This is great.
I have s3etup the qrz in wrl. It exported once automtically now nothing.
@WQ1X Hey Sean
We’ve pushed some updates since the database upgrade. I just checked your account and it looks like you dont have ‘Auto Export’ enabled in the QRZ Integration.
I just re-enabled it for you manually.
They should start auto exporting now.
Thank you
