Hello, Can you explain how WRL CAT should be configured to Integrate and port the logging over to N3FJP? Love WRL but need to have all my various logs updated simultaneously which N3FJP does and since anything we import does not count toward awards, it’s sort of a PITA to have to enter all contacts manually for WRL awards. Am I missing some easier way to get credit without having to hand type in all my FT-8 contacts?
Where exactly are you running into a problem. I have N3FJP Amatuer Contact Log up and running. I go to settings make sure the TCP API Enabled is checked and listening on port 1100. I then run WRL CAT COntrol Beta 1.0.2. I go the gear icon for the settings. I then select the N3FJP tab, make sure the UDP port is set to 1100, select which WRL logbook I am syncing to, and then click start listening. Any logging I am doing is either in N3FJP directly or I am sending from software to it like WSJT-X. All this is on my same laptop.
I finally got it working. On the front page, it shows a 0 and a green dot.
Below shows connected. The zero on the left of the green dot I would think would count the logged contacts so that was also throwing me off. It is logging from N3FJP now which is great.
I am not sure what that 0 is for though. If a count, that is definitely not working. I am showing 18db though so that meter is working.
Tnx,
Jay Goldberg
UKULELE JAY BBQ
