Integrating N3FJP with WRL Not working
I followed the instructions to integrate N3FJP but not transferring between the two. I’m sure this has been addressed, so please point me in the right direction.
Thanks so much!
K4MES
@K4MES Sorry you’re having some trouble, you simply just need to go into N3FJP → Settings → Application Program Interface (API) and then select the top checkbox “TCP API Enabled” and set that port to whatever you want & then click the done button. Wait a second and then go and open the WRL Cat Control app and set the port to the same thing you did in N3FJP and click the ‘Start Listening’ button. Give it a sec and then make a contact and it’ll work. I think the starting order does matter.
I hope this helps
Certainly give it a try. Thanks!
