Integration order between QRZ, WRL and LoTW
Hello - New ham here. (Maybe this topic has been covered before but I couldn’t find it). I have been licensed about a year and am now an AE. I have a couple questions on the best and most logical order in which to integrate WRL, QRZ and LoTW and how they work together. This is also important if I make corrections to one, what happens (if anything) to the entries in the other platform? I first started logging only on WRL and consider that my base log. I recently exported to QRZ and they are now integrated and it works well. Next I want to integrate/connect to LoTW but want to understand the best way to do that first..
1). The question is should I connect WRL or QRZ to LoTW? Seems like I should go with QRZ. What are the pros and cons?
2). If I make a correction to a log entry on QRZ after spending time resolving inconsistencies with other members, does this correction get fed to WRL and the WRL entry corrected?
Thank you ahead of time for any input and recommendations.
@NW6Y Currently its basically just a one way street (especially with LOTW as we only import from LOTW and not export to LOTW).
I would just setup import and export to QRZ and if you want to export to LOTW just export an ADIF from WRL and import into LOTW.
Currently we will only pull in QSO’s from QRZ via the import functionality if the QSO’s are already not in your logbook. So making a QSO in WRL, it gets exported to QRZ via the export functionality, if you make a change to it in QRZ it wont send back to WRL.
I hope this helps
Thank you. That answers my questions
Nancy
