Issue trying to download WRL CAT control and HAMLIB
i keep getting the same message when i try to download the wrl CAT file. Cant say i have seen this message before, what do i need to do to get window to allow the download? how do i “trust” the file?
thanks
@M5GVY There should be an allow button somwhere next to the downloads window or a setting in your browser somewhere. What browser are you using, firefox?
@M5GVY If its firefox like i think it is there is a setting in the Settings → Privacy & Security → Security section that says ‘warn you about unwanted and uncommon software’ that should allow it.
i’m using msoft Edge. its downloading a .crd file.
@M5GVY thats because its not downloaded, its trying to download the .exe installer and edge doesn’t like you downloading exe’s. Go into your settings then ‘Privacy, search and services’ then goto the ‘security’ section. Un-toggle the ‘block potentially unwanted apps’. If that doesn’t work uncheck the one above it that says ‘Protect from harmful sites and downloads’ then after its downloaded re-enable it.
@M5GVY we are going to be adding a certificate to the cat control app soon as well as cat control will be built in natively into the desktop app when we release in the next couple of months.
Thanks again for the quick response. I’ll give it a try later. Loving the wrl experience.
yessir no problem at all
