Log combining
Hello all. I just uploaded individual logs from another program from previous POTA activations. When uploading I went through the process to create new log books for each individual log. However once uploaded all the new logs have been added into the last log I created for my last POTA activation and not into the new logbooks I have created for the imported logs.
Welcome to WRL.
That should be easy enough to resolve. Someone else will probably suggest something easier so I’d wait a bit and not react right away to my suggestion.
Delete all the contacts you uploaded - easy to do in the QSO Manager.
Upload one of your external logs - when complete merge those contacts into the WRL log that you want for that activation.
Rinse, Repeat until completed.
An alternative would be to leave everything in place, go into the QSO Manager and select all the contacts from a specific activation and then merge just those into the WRL log that you want them to be in.
Again, wait to see if someone else has an easier/better solution as I’m no WRL expert.
I believe this link follows with what @W7YBY talks about in his alternate method.
log management,
qso-manager-how-to-bulk-update-contacts
Hope this helps
