Multiple County Logging
In the 2026 SC QSO Party, I worked two counties simultaneously (sitting on the county line). For each contact, I worked the same callsign twice, one minute apart, in two different counties. However, when I attempt to upload the two logs, WRL sees them as dupes. They are not dupes, and it’s important to county hunters to have their contacts in the log. Is there a way to upload these two logs without them being seen as Dupes?
@KQ1S Hey Bill, most likely not if you are uploading via an adif. I would suggest just manually adding the second QSO and it will allow you to add it.
Ok, I’ll give that a try. Thanks for the reply.
