I just thinking about any contest does not have level of an attic antenna, because it cannot be comparing with others….
73, kd9wif
73, kd9wif
@KD9WIF Hey Vladimir,
I’m not sure I understand what your asking. Can you clarify?
Hi,
Because of condo antenna installation restrictions, a lot of HAMs and myself included in these kind of limit to use good outside antenna. That is why I work with my attic antenna which has not comparable specification with outside antennas. So, there will be great to add in any contest an antenna level as an attic antenna.
Thanks for your response.
73,
KD9WIF
Hi Brad,
Hi,
Because of condo antenna installation restrictions, a lot of HAMs and myself included in these kind of limit to use good outside antenna. That is why I work with my attic antenna which has not comparable specification with outside antennas. So, it will be great to add in any contest an antenna level as an attic antenna.
73,
KD9WIF
@KD9WIF So you can goto your profile in the webapp and then click the ‘my station’ button and add your radio and antenna
Then you can go into your logbook (or contest logbook after enrolling in the contest(s) from the ‘contest’ page) and then you can set your radio and antenna via the quick settings right above the logging fields.
I hope this helps!
I think possibly he means, a special contest category, to only compete against people that have an attic antenna!
@N0WRL ah ok i must have misunderstood.
Roger, Roger!
