Notes Field in Logbook
Hello,
Is there a way to put a note in the Notes Field before I start logging so the same note will appear on each called logged, without having to re-enter it for each call?
Thank you.
Hi Charles @NP3K
Welcome to the WRL community chat!
No, this is not offered.
But there is the following solution:
After you have logged all QSOs, you can filter these QSOs in the QSO Manager and use Bulk Edit to uniformly rewrite the Notes field for all selected QSOs.
73 Pepe
That works. Thank you so much!
