Can you please change “Federal Republic of Germany” to just “Germany”. I know the first is correct but as a german I tell you no one uses the long name. Just germany.
Best regards an vy 73
You are absolutely right. All other counties are also in the short form (e.g. “Mexico” and not the official name “United Mexican States”).
73 de Pepe HB9EVT from the “Swiss Confederation” ![]()
@DO7MEW Thanks for reaching out!!
I’ve added this as a mini feature for discussion, we’ll have a chat about this as a team and see if there are any unforeseen repercussions of making this change ![]()
Hi there and good morning, fellow hams.
I just wanted to report a bug with the same topic. In fact, there is an issue with the leaderboard.
When you open the drop-down list and type in “Germany”, you will find “Federal Republic of Germany”, which is fine for me, basically.
The thing is that this page doesn’t actually reflect the user’s location, which is “Germany” for me. So on the “Federal” page, you don’t see any contacts at all.
The drop-down list links to “/leaderboard/detail?country=Fed. Rep. of Germany”.
When you select Germany on the world map, that links to “/leaderboard/detail?country=Germany”. And there’s the actual stats.
Have a good one and 73,
Dan
@DL9PD Hey Good Morning Daniel,
Thanks for pointing this out! I’ll make the team aware of this.
