POTA 2fer parks activation [IMPLEMENTED]
I have not found a way to log 2fers… in the logging system’
Hi Paul :wave:t3:
The way for now is to register each contact as a separate entry.
Al. Thanks for the reply. At least twice a month I activate at a location that is a 2fer and a few that are 3fers. I am able to enter the QSO once and duplicate that log in HAMRS
with the other park number. I have tried to upload 2fers with different park numbers into WRL, your log gives me a 0 QSOs on the second park. I am guessing the QSOs are considered Duplicates. I’m looking forward to becoming a paid member as soon as the POTA bugs are worked out. As you pointed out I would need to log in two logs for each contact That would make using your log too much effort. I recommend the WRL allow you to pick multiple parks and create two logs that then can be loaded on the POTA site automatically or uploading the ADIF file to a folder and then to POTA.
Thanks for your help
Paul K5CIP
Hey!
We’ve gotten a few similar reports… likely what we’ll implement is allowing for comma separated park numbers, similar to a lot of other suites. We’ve hit some unprecedented growth over the past week or two, so be patient! We’re taking in a lot of feedback and spending some time cleaning everything up for everyone.
As an activator native in app, you are able to start a 2fer, 3fer, 4fer, etc, and export each individual parks log, but yeah if you work a 2fer we need to improve that flow. Thanks for the call out!
Just following up here - you can now log 2fer, 3fer etc!
Does this apply to logging POTA 2fers as a hunter as well? I thought I tried to comma separate the parks without success. I used this format: US-####, US-####. Is that the correct way for a hunter to format multiple parks?
Hi there, so how do you do this, just go to the Park and enter the multiple parks separated by commas?
Hey guys!
To enter multiple parks:
  1. Start typing the park number, and it will bring up a list of parks
  2. Click the park and it will add it to the contact
  3. To add a second park, start typing the next park number and select it from the list!
This will work for adding multiple parks, up to 5 today and we will be adding more than 5 soon!
