Is there a way to log a POTA 2fer using one log? Does WRL log allow you to choose two or more parks on the same log.
Hi Paul
We have it on our roadmap, this function will be available soon. Thank you
73’
Hi @K5CIP , yes, you can set two parks at the same time! When you are creating your POTA log, just select both parks. We support up to 4 parks at the same time
I was able to pick two parks. When I attempted to export the ADIF it only identified only one park. Can you please give a step by step to get the get ADIFs for both parks.
Hi Paul! If you go to the Logbook Settings for the logbook you used for POTA, you will see two buttons, one ADIF for each park:
Let me know if that works for you!
James, Thanks for getting back to me. I followed your instructions. When I exported the first park it exported 18k worth of data and it uploaded onto POTA. I attempted to upload the second park and the upload was only 1k and when I went to upload into the POTA data base it was not recognized. The second park data is not duplicating the contacts under the second parks file
Thank you Paul!! I think this might be an issue with the park records not existing on all the records… we’re investigating this and we’ll let you know ASAP. Thanks so much for this report, I’m sure if it happened to you it could happen to lots of users!
I am also wondering about this. I think when I started a general log, and then set it to POTA style it worked out. However, when I selected “start new pota activation” and entered 2 parks that way I only got the one “Export ADIF” and neither specific parks. POTA site recognized one of the parks, but not the other and called it a duplicate… Not sure what the issue is. Guess I will start with a general log and use the pota template
@KQ4DUX Thank you for reaching out! Could you send me a screenshot of the page that should be displaying the individual park export buttons?
@KQ4DUX Just checking to see if this is still an issue for you. If so, can you provide us with a screenshot of the problem? Thank you!
Sorry, haven’t been able to take a look. I think I edited the log and got it to work for uploading to POTA. I will let you know when I do a new activation. Thanks for checking with me.
You’re very welcome! We want to streamline this process for you, so if it still isn’t working next time we’ll jump in and see what the problem is. Thanks!
