<hi I suggest a function in the qso manager where you can click on the latest qso and the qso you want to end the list with. There you click on qso,t and at the same time press the shift key and all qson between these two choices will be marked. This makes uploading today’s catch significantly faster. Is this possible to do?
I like it a lot, like adding the mfsk mode as Adif master does not like that it says FT4 in the log, I always get an error message because of FT4 which I now have to change manually to mfsk.
Thanks for a good program, hope the cat control works soon.
@SM5MEK This is something we can look at adding possibly however with that said, there is currently a way you can select by date range using the ‘All time’ drop down from the top right of the QSO Manager (see below).
As far as the MSFK/FT4 thing, we have some changes planned to show the user FT4 as the mode (since its a sub mode of MFSK) but when its exported as an ADIF or exported to QRZ via the QRZ export integration it will be sent as MSFK since thats what they are expecting.
I hope this helps
