Rig control
Does the app include rig control for FLEX and if so, does it use the flex API or CAT?
Thanks
Greg
AB7R
To answer your question it using CAT control. You can use a flex with WRL rig Control. Whether you’re using Windows or Mac OS. You will need to use CAT control for either OS and setup up a port for something like 50000 or 5002 that are my two common ports I use. Happy to further help if you need it. I
Thanks Marvin!
