Rumlog -->WRL N1MM-->WRL
When importing from Rumlog in real time using the new WRL Cat Control app this happens during the import. It changes the frequency.
Also, can you fix the issue that “New” user can attach more than one picture at a time.
Andreas-KL5PF
@KL5PF Hey Andreas,
Currently we dont support rumlog but with that said looking at your screenshot, yes it does look like its because for whatever reason rumlog is using a comma instead of a period/decimal like all the other loggers do.
Brad, I disagree: Rumlog uses commas to separate thousands and the dot as a decimal point.
I think the difference that causes the problem is the unit: in WRL the unit is MHz, and in Rumlog it is kHz (see screenshot).
This is just a note. Because what Brad @K4AZE said still counts:
73 Pepe
@HB9EVT Pepe, this is happening because we are taking whatever rumlog (or any other logging app) provides as the frequency and passing it to WRL so if its incorrect (regardless of how its formatted) coming from the other logging app it will be incorrect in WRL.
Thanks Gents! I knew it was something retarded like that. So when is the desktop version for MAC going to be released again?
@KL5PF I can’t provide an exact date but its coming within the next couple of months. We had to push it back a little due to prioritizing our database upgrade, which is almost complete and ready for testing. Once that is done the next top priority is the desktop app as far as major features are concerned.
If you need a beta tester for Mac, I’m willing to help you out.
@KL5PF Yeah for sure when it is almost ready we’ll put out a note to the beta testers group. Just go here BETA Testers Needed and just make any post and i’ll get you added to the group.
@K4AZE It appears that you have implemented a solution. I can observe the QSO flow in Rumlog format, and then, a millisecond later, it is converted to the correct format.
update: 5 of 6 did flow over correct. I keep watching it tonight.
@K4AZE The one QSO issue yesterday autocorrected itself after the next QSO. So that part is working. The next issue is that the flow into QRZ is the band. Please review all the screenshots with N5TIT QSO.
WSJT-X to Rumlog
Rumlog via N1MM to WRL
WRL upload function to QRZ
As you can see, the issue is with the band transfer.
73s
Andreas-KL5PF
looks like its setting the band to “14” in WRL which in turn is getting sent to QRZ via your WRL QRZ Auto Export, when it should be being set to 20m in WRL which would send to QRZ as such. So the issue seems to be its not getting pulled/set properly from rumlog into WRL.
Sure looks like that. I entered this manually in Rumlog.
On the log screen, there is no option to enter a band (Rx Band) unless you are using satellites.
On the log, it auto-generates the band.
Andreas-KL5PF
