Seeing the WFD log in my Logbooks
I am registered and want to use WRL for my WFD logging. I can go to the Contest page and select Log Contest Contacts, setup my log with my information and give it a name and description and save the setup. The only place that this log appears is under the Contest area and not my list of normal logs. Is this the expected result and will this ever appear in my normal log? ie… after the contest? Just want to make sure it is working correctly prior to the WFD event. Regards, 73, Rodney KJ5FWC [AE] [VE]
Hi @AE5TX !
First off, thanks for using us for field day!
There seems to be a small bug where the winter field day logs aren’t showing up in the regular logbook list - we’ll check on this and get back to you right away. Everything will be set in time for field day!
A post was split to a new topic: Questions about North American QSO party
We have updated this now so you should see it in your logbooks!
To help identify the root cause - do you remember if you enrolled in the contest on the website or mobile app?
Thanks!!
I believe it was the website.
Thanks for your prompt response.
Looking forward to this and many more contests and features.
Regards,
Rodney
KJ5FWC
Yahoo Mail: Search, Organize, Conquer
@AE5TX thank you so much for your help and confirming.
I hope to work you on Winter Field Day and thank you for supporting this project :pray:
