Sending QSOs to Third Party
Is there a way to send out QSOs from WRL logs to a third party eQSL service? I know we can use N1MM etc to import in real time, but how about output to a service such as QSL Creator, which supports other logging services. I know we can output to QRZ and LoTW but how about other services. Here is the connection info.
Upload your QSOs in real time via UDP port (optional)
Use the UDP protocol to send your QSOs to our service in real time.
Type ADIF_MESSAGE (XML also supported if using N1MM, HRD etc..)
IP Address 109.228.61.107
UDP Port: 6555
Works with Log4OM, N1MM, HRD, Station Master Pro, and many other logging programs. QSLs submitted via this method will be emailed out automatically.
@VE9CF Currently no. We are working on something similar where you can send them straight from WRL though.
