Open UDP Listening
I would like to suggest a feature that allows Ham-Made software to send logged contacts to selectable log books IN WRL logger. Example, A member of OMISS created an award tracking dashboard that can forward contacts from netlogger to N1MM , AClog and HRD via UDP. Since WRL is my main logger, Id like to be able to use this program and others developed in the future to be able to automatically send logs to WRL
@N2QC Im sure this is something we can setup. Currently you could probably do this with the WRL Integrations app (formerly WRL Cat Control app) and just set the UDP port the same in that application as you set in the WRL Integrations app in the WSJTX section. It should still send the QSO broadcast data to your WRL logbook, unless the QSO data is vastly formatted differently. What is the name of this app and a link to it would be helpful, we can try and pull the data and see how its being sent.
This is the link to the software. Its a companion app for Net Logger.
https://github.com/NmX69/nl-net-buddy-releases
Mike
@N2QC Sorry for the delay in getting back to you on this. We’ve been swamped with getting everything setup for WRTC 2026.
I’ve added this as a feature request.
