WWA Integration Hamaward.cloud
Hi Everyone, I will be running VE9WWA this January and we need to use their logging software, but I know it is integrates with N1MM for example, would it be possible for WWA logging thru Hamaward.cloud to send to WRL
@VE9CF Potentially, can you shoot over some documentation on integrating with n1mm and we can try an mimic it. Without knowing anything about hamaward.cloud I would assume if you have the WRL cat control listening for QSO data via UDP (using the n1mm settings, and if its able to send via the local network) that it would work out of the box. However with that said we may need to add a way to enter and listen on a specific IP address. Any documentation and/or instructions that you can shoot over will be helpful and we can start taking a look at it.
Here are some more documentation
@VE9CF Hey Stuart
So from what i’m seeing you should (in theory) just be able to go into the WRL cat control app settings and goto the N1MM tab and set the port to 12060 and select which WRL logbook you want the QSO’s to go into and click the start listening. Then when you log a contact it should goto both hamaward and WRL.
Additionally if you already have WSJTX setup and working with WRL Cat control you can goto the WSJTX tab in the WRL cat control app and start listening there as well and all should just work.
I’m happy to jump on a quick google meet or something with you and we can test this theory if you’ve got a min sometime.
When are you going to be running this station through hamaward?
Thanks…I look into this after the RAC contest
