Will Linux ever be supported?
@W9AFJ Hey Scott,
Yes. Currently the web app works on linux, and there is a cat control build for linux in a deb and rpm as well. The desktop app will have the same once its beta is released.
And just as an FYI if someone else comes here for info, a few of us have been running everything fine on Arch based distros also, so chances are it will run on ANY distro.
This weekend I played with the Linux Cat Control;
Issue: when I got the cat control connected. I opened WRL in Web browser/Log Book/Spotting(Pota). If I manually change the frequency on the radio; frequency would be updated on web page. If I select the call sign on the spotting page, the frequency on the radio would not change. I have had similar issue run on Mac; sometimes it works sometimes it does not.
Is there a certain sequence I need to follow; IE;
- Open WRL Desktop App
- Open WRL Cat Control
- Log into webpage via Cat Control (sometimes I will get a failure here)
- Connect radio USB
- Connect Radio in Cat Control
Set up: HP Laptop running Linux Mint Cinnamon
Installed: Linux Desk Top, Linux Cat Control
Radio: Yaesu FT710
Configuration
1. Hardware & Drivers
USB/serial cable connecting the radio to your Linux machine.
USB driver for your radio (e.g., “ICOM 7300 USB Driver”) — install it so Linux can communicate with the device worldradioleague.com.
On Linux, USB-to-serial adapters (like CP210x) appear as
/dev/ttyUSB0,/dev/ttyUSB1, etc. You can check with:ls /dev/ttyUSB*
dmesg | grep ttyUSB -
Ensure your user is in the
dialoutgroup for serial port access:sudo usermod -a -G dialout $USER
2. Radio Settings
In your radio’s Operation Settings or General menu, set:
CAT Rate to match your Linux port’s baud rate (commonly 38400 or 9600 for stability) worldradioleague.com.
CAT Time Out Timer to ~100 ms (avoid 10 ms to prevent timeouts).
