A contest leaderboard
Hi,
There will be good to add a new function such “A contest leaderboard”, because existing leaderboard shows, probably, a total score of all contests.
Thanks you in advance for consideration.
With best regards,
KD9WIF
73!!!
@KD9WIF Each contest has its own leaderboard. When you go into a contest there is a leaderboard link at the top of the page.
Here is the leaderboard for the ARRL Field Day 2026:
You can goto the ‘Upcoming Contests’ page and click into each contest and see this.
Upcoming Contests: https://app.worldradioleague.com/contest/upcoming
For current/live contests you can do the same thing. Here is the only live current contest which is the “2026 World Soccer Tournament Special Event”: https://app.worldradioleague.com/contest/contest-detail?tab=contest_home&contest_id=dbabbd32-f893-4329-ad5b-ea6265a1e485
There is a ‘Leaderboard’ link at the top as well as a ‘Top 10 Leaderboard’ on the same page as the link directly above.
This “2026 World Soccer Tournament Special Event” is a good example that shows a wrong leaderboard because of this rule requires radio connections with only with 16 call stations from the USA, Canada, Mexico and one bonus station.
The first four leaders have QSOs with callsign stations that do not fall under these rules.
Thanks again for your response and business,
The best wishes to all of the WRL!
73,
KD9WIF
@KD9WIF This isn’t an actual contest though and was only added by us at the request of several users. So I wouldn’t expect for the leaderboard to be accurate. Also, we are not calculating scoring (outside of 1 point per qso) currently. This is part of the major enhancements to the contesting side of WRL.
Thanks Brad for your response.
Regards,
Vlad etinger
73,
KD9WIF
Hi,
By the way, I could not find the WW AWARD 2026 contest which became from June 29, 2026 to Julay 5 2026. Is this something different?
Thank you.
KD9WIF
@KD9WIF This was not on the list of contests i pull from so it wasn’t added. Since we’re already two days into it now I dont think it should be added now.
Thanks for your response.
One question more: the leaderboard for the contest 13 Colonies shows not correct, because leaders from 1 t- 6 have connections with stations which not correct with the contest.
kd9wif
@KD9WIF Yes correct because again we have not added this functionality yet.
Hi,
Please explain how I can submit my CABRILLO log of participation in WRTC 2026?
I tried to submit contest logs using the ARRL Contest Log Submission IARU HF, but it could not recognized this WRTC 2026 EVENT.
Thanks for a response.
KD9WIF
@KD9WIF i replied on your other post about this - Please explain how I can submit my CABRILLO log of participation in WRTC 2026?
The Cabrillo file generate name of this event “WRTC2026”. This name could not accepted by ARRL Contest site. Finally, I found that the name need to be changed to IARU-HF.
Thanks,
KD9WIF
@KD9WIF Yes, I mention that in my reply. Simply need to open the log in a text editor and update the contest name.
