A few ADIF export issues
I’m having a little trouble with export to ADIF after logging for POTA.
  1. Most programs use (band)m for their band field(for example 20m), however, I found WRL to export only “20” instead of “20m”. This was an issue when uploading to QRZ.
  2. “Their QTH” doesn’t export, “My Gridsquare” doesn’t export, “My QTH” doesn’t export.
hopefully “my_sig_info” and “sig_info” will be included in the POTA template?
I also have all these versions of 20 meters showing up in my stats. Any way to consolidate these?
Hello @NF0P
Both situations have been reported, and the developers are already working on it. Thank you 73’
The failure to export an “m” after the band number is still an issue with the latest release. For example, the ADIF file exported by WRL list the 20 meter band as “20” instead of “20m”
Andy, It had been solved and in the new version the problem returned?
It had actually never been resolved. I just wanted to make sure it was on the slate to be fixed.
Hi Andy, I thought it was resolved, I just reported it again. Thanks for letting me know
Hello @N0APX
When you can, can you check it again?
Thanks :slight_smile:
Works perfectly now! Thanks, Alfredo! That will definitely speed up my process!
Great, thanks to you for reporting :hugs:
