Add Name to Logbook List, Allow Customization and Size Change
Please add the Ham’s name to the list of logged contacts in a logbook. It would be great if the notes were also displayed. Perhaps the thing to do would be to add a slider in the middle of the screen to change the size of the entry area and give more space to the grid so more fields can be displayed. A bulk edit of ancillary data for the list would be good as well, such as the notes, frequency, mode, etc.
@KC1ZZJ Hey Charles,
This is just a logbook template. I’m assuming you are just using the ‘Default WRL’ logbook template. There are many templates available for free members and as a member you have the ability to create your own logbook templates which allows you to add/remove fields, rearrange fields, change the look, etc.
You can change the logbook template by clicking on the name in the quick settings bar (see below, highlighted in yellow) and then change it.
I think what you are looking for would be the ‘All Fields Template’ or possibly even the template I use the most which is called the ‘WRL POTA/SOTA/WWFF/IOTA Hunter Template’ which as all the fields plus all secondary fields needed for hunting.
Also, when creating a new logbook you can select a different template
Regardless of the template, this data is always saved (ie name, gridquare, notes, etc) in the QSO data.
@K4AZE I believe he is talking about the Log list here:
This is coming soon! Log in - Asana
@N0WRL hahahaha face palm. i think your right after re-reading it
Thanks, Brad. I appreciate your response. This doesn’t seem to change the fields displayed in the right-side table, though. In particular, I’m interested in seeing the name and the note.
@KC1ZZJ Yeah i mis-read your post / misunderstood what you were asking. Currently there isn’t a way to do this. We will be adding options for this in the future though
Thanks @KC1ZZJ this is a great request. It’s been on my list but haven’t gotten to it yet. Now that you’ve mentioned it I’ll give it a little extra priority :slight_smile:
Cheers and 73!
