Custom Fields?
Is it possible to add 3 or 5 custom fields to a logbook? You’ve already built a great database, but it would be even better if users could add custom text fields for data points we want to track but aren’t typically included. I understand that the ADIF file standard might not let these be imported/exported but it would be a start!
KC1WZN
Todd
@KC1WZN Hey Todd,
Yes we have the ability currently using the custom logbook templates. You can access this via creating a new logbook (or an existing logbook). If you are creating a new logbook, under the ‘Template for Logbook’ dropdown scroll down to the bottom and click ‘View Templates’. If you are using an existing logbook you can click the template name right above the ‘band’ field (see screenshot) then click the ‘view templates’ link. From there you can click the ‘Create New Template’ button in the top right. This will allow you to add/remove/rearrange your logging fields as well as change the themes for them. One thing to note is this will only currently work correctly for the web app. We are working on some changes for this to transfer over to the mobile app which is tricky since there is very limited space constraints on the mobile apps.
I hope this helps!
