Another Contest Cabrillo Export Issue
I exported my log for the NA SSB Sprint and got these errors. It really does not make sense that WA in my logs became WASHINGTON when FL and the other states stayed with the abbreviation. Also it doesn’t seem to be exporting the time.
Too many errors (>25). Checking stopped.
Line 23 Only 10 fields were found on this line. Something is missing.
QSO: frequency mode date time CallSent QSO#Sent NameSent StateSent CallRcvd QSO#Rcvd NameRcvd StateRcvd
QSO: 14200 PH 2026-02-01 0001 W2FCP 001 K7SS 3 DAN WASHINGTON
Line 23 Sent name missing or must contain only alphabetic characters.
Line 24 Only 10 fields were found on this line. Something is missing.
QSO: 14205 PH 2026-02-01 0003 W2FCP 002 KG2MM 2 MIKE FL
@W2FCP Ok so after looking at your account and logbook there are some issues.
First, and most importantly you haven’t added your exchange information in the ‘My Exchange"‘ field under the log contact button. This HAS to be filled out for every single contest before exporting your Cabrillo logs.
Also, we are just pulling the data from the contest exchange fields, so if you enter Washington, Washington will be in your log instead of the abbreviation.
The time is being exported in the Cabrillo properly.
To resolve this, simply add your exchange information in the ‘my exchange’ fields making sure to click the save button. Then goto the records that have the state spelled out and update the data to the state abbreviations and then just re-export your log.
