QSO Party Logs Rejection
Submitting this past weekend contest logs for the Hawaii QSO and the Ohio QSO Parties, both of the logs were rejected due to bad Cabrillo formatting. In the Hawaii log, it seems the spacing of the last column was wrong. In the Ohio log, my state info was not listed.
Someone needs to fix these issues.
Thanks.
@KN4JN Good Morning,
So theres a couple things here, one is you’ve got to make sure you’ve added ‘Your Exchange’ including the county even if you its not what your sending (see screenshot), however there is an issue with the export that we’re pushing a fix for. In the meantime i’ve updated your logs manually and i’ve attached them here. Just rename the file from KN4JN-OH to KN4JN and upload to the Ohio QSO Party site, same with the Hawaii one.
Let me know if you need anything else.
Just an update. we’ve pushed a fix for so it will export properly going forward.
