Cabrillo Export Not Working for me
Hello.
I’m trying to export a log file to a Cabrillo file. The cabrillo export generates what appears to be a proper header, but no QSO information. The log looks like this-
(at the end)
**SOAPBOX: **
QSO:
QSO:
QSO:
QSO:
END-OF-LOG:
There are the correct number of QSO lines in the file, but they are all blank. Just shows
QSO: (no more information)
I’m obviously missing something.
thank you for your help,
-john
@KN6FVK Hey John!!
Sorry your having some trouble!!! Which logbook or contest are you trying to export the Cabrillo for? I’ll make sure you’re able to export correctly.
@KN6FVK Hey John,
I just looked at your account and you have 3 logbooks. Two pota and one regular logbook. It doesn’t look like either of those 3 are a contest logbook though so exporting to a Cabrillo wouldn’t work right as there is no exchange fields to pull from.
When participating in a contest you’ll need to goto the contest page (World Radio League) and then select the contest you want to enroll in and either click the ‘Join for free’ button on the main contest list page (link above) or go into a specific contest and click the ‘enroll now’ or ‘join for free’ buttons. This will create a contest logbook with the correct exchange fields. Then once your done you can export to a Cabrillo file.
I hope this makes sense.
Hello Brad,
Sorry for the delayed response.
This issue is not with my personal account, it’s with our Club’s account (which I’m logged into now) - W6LIE.
This is for Field Day (… yes - I know, tomorrow) - hahaha.
I did join / create a Field Day log.
One question, when it asks for “Operators” - I’m entering “MULTI-OP”. Am I supposed to enter all of the operators that we had?
Thank you for your time and help,
-john
@W6LIE Hey John!!
Ohhh ok, yeah that detail for sure matters haha.
Ok so what you’ll need to do is go into the logbook and then click ‘Your Exchange’ underneath the Band and Mode fields and enter your club info there for your exchange and click save. Then you’ll need to goto the logbook settings (gear icon in the top right), then make sure all the data if filled out there, especially the ‘Contest Settings’ at the bottom. Then click the ‘Export Cabrillo’ button and when the Cabrillo header editor pops up fill all that out and where it says ‘Operators’ enter each callsign separated by a comma. IE: N0WRL, K4AZE, N0APX.
Then scroll down to the bottom and click the ‘Export Cabrillo’ button. It does look like there is a missing header option though for ‘CATEGORY-OPERATOR’ that youll need to manually enter after you’ve exported the Cabrillo.
You can just double click the log file that gets exported and open it in notepad or any text editor and add a line above the ‘CATEGORY-BAND: ALL’ line and add in ‘CATEGORY-OPERATOR: MULTI-OP’ then save the log.
Example:
CLUB: W6LIE
OPERATORS: N4BFR, KN6FVK
CLASS: A
SECTION SJV
CATEGORY-BAND: ALL
That will get you want you need. I hope this makes sense, Let me know if you have any issues, happy to help.
…well that was easy! - /sigh - hahaha
It worked per your instructions!
I will have to go check my personal account next, make sure I have all that info populated.
I appreciate your time and help,
73-
john
KN6FVK
Yessir no problem! Glad it worked out! When i checked your personal account it didn’t look like you had the field day contest log (i.e. the contest exchange fields weren’t there) so that one might be a little more difficult/complicated but just ping me and I’m happy to help figure it out!
4 posts were split to a new topic: Ability to Create a Custom Contest Logbook for Non-Supported Contest
Try to do it on the next day after it, because, probably, a contest time was not finished by WRL.
@KD9WIF I’m not sure I understand your comment. Can you ellaborate?
I had the same problem just 10 minute after the contest ended. I decided to repeat Cabrilo Export on the next day and it was successful.
So, pl;ease try to export on the next day…
73,
KD9WIF
