How do I find a file to convert to cabrillo and upload to ARRL? N4CRB
@N4CRB You just go into your contest logbook in WRL and make sure you’ve got your exchange added to the ‘My Exchange’ field under the ‘log contact’ button and then goto your logbook settings then click export at the top then click the ‘export cabrillo’ then fill out the cabrillo header information and click export at the bottom of the screen.
I found the locations where the files were and was able to export the Cabrillo file, but I got an error message saying that something was missing. I suspect it’s that exchange that you were telling me about in your reply. I’ve got the blue exchange field where I was putting location and serial numbers during the contest. Is there something else that needs to be in there?
@N4CRB Yes the ‘My Exchange’ field. ( see attached . you enter your state abbreviation there.
Yeah that was the problem. Thanks..
