My QSO’s are blank when I export to Carrillo. I see the header and then QSO: QSO: etc with no information. I was able to export the adif to N1MM and create the Cabrillo file there. Is what it is…-W1GUU
@W1GUU Let me take a look for you and if something isn’t right i’ll push a fix real quick. Gimme just a bit to dig into it and i’ll reach back out shortly.
@W1GUU Hey Gary,
I just looked at your logbooks and im not seeing the route 66 contest logbook. Did you goto the contest page and entroll in the contest and use the logbook it created or did you create your own logbook? If the latter then where were you entering the contest exchange data?
