Apps Don't Load Cat Control Options
I have an issue, for my Kenwood TS-850S. When I go to cat control in desktop app, it displays only CI Network (ExpertSDR/RemoteHamRadio) #99001 and the error rigctl exited with code 1. WRL Cat Control app for web app doesn’t work either. However, I can control the rig just fine using flrig.
I installed from the web download on the homepage for .deb.
My system and OS are:
neofetch
             ...-:::::-...                 nathan@sokyrad-desktop
          .-MMMMMMMMMMMMMMM-.              ----------------------
      .-MMMM`..-:::::::-..`MMMM-.          OS: Linux Mint 21.2 x86_64
    .:MMMM.:MMMMMMMMMMMMMMM:.MMMM:.        Host: OptiPlex 3050
   -MMM-M---MMMMMMMMMMMMMMMMMMM.MMM-       Kernel: 5.15.0-194-generic
 `:MMM:MM`  :MMMM:....::-...-MMMM:MMM:`    Uptime: 1 hour
 :MMM:MMM`  :MM:`  ``    ``  `:MMM:MMM:    Packages: 4598 (dpkg), 28 (flatpak)
.MMM.MMMM`  :MM.  -MM.  .MM-  `MMMM.MMM.   Shell: bash 5.1.16
:MMM:MMMM`  :MM.  -MM-  .MM:  `MMMM-MMM:   Resolution: 1920x1080, 1920x1080
:MMM:MMMM`  :MM.  -MM-  .MM:  `MMMM:MMM:   DE: Cinnamon 5.8.5
:MMM:MMMM`  :MM.  -MM-  .MM:  `MMMM-MMM:   WM: Mutter (Muffin)
.MMM.MMMM`  :MM:--:MM:--:MM:  `MMMM.MMM.   WM Theme: Mint-Y-Dark-Blue (Mint-Y)
 :MMM:MMM-  `-MMMMMMMMMMMM-`  -MMM-MMM:    Theme: Mint-Y-Dark-Blue [GTK2/3]
  :MMM:MMM:`                `:MMM:MMM:     Icons: Mint-Y-Blue [GTK2/3]
   .MMM.MMMM:--------------:MMMM.MMM.      Terminal: gnome-terminal
     '-MMMM.-MMMMMMMMMMMMMMM-.MMMM-'       CPU: Intel i3-6100 (4) @ 3.700GHz
       '.-MMMM``--:::::--``MMMM-.'         GPU: Intel HD Graphics 530
            '-MMMMMMMMMMMMM-'              Memory: 7489MiB / 31977MiB
I cloned the hamlib repo and built it on my computer with no errors. libhamlib-dev and libhamlib-utils are installed via apt. hamlib-utils is not a valid package on my freshly updated apt repo. Verified rigctl has my radio and is working:
nathan@sokyrad-desktop:~$ rigctl -l | grep 850
  2009  Kenwood                TS-850                  20250515.0      Stable      RIG_MODEL_TS850
  3042  Icom                   IC-R8500                20250517.0      Stable      RIG_MODEL_ICR8500
  3075  Icom                   IC-7850/7851            20250517.8      Stable      RIG_MODEL_IC785x
I have used it successfully from my laptop using mint, but this Dell Optiplex it doesn’t play nice.
