Is there a way to hook up a Flex Radio via SliceMaster? What SliceMaster does is create a port on #7810 that sends the current TX Slice as the radio frequency rather than a specific Slice frequency all the time. This is HUGE for all Flex Radio with 6600s and 8600s. I tried the Flex Rdio 6xxx radio option with Port #7810. It says it’s connected, but I’m not seeing the frequency populate within the logbook anywhere to know it’s actually connected. Guessing I’m just doing something wrong.
Disregard. I figured it out. The Flex Radio 6xxx option and Port#7820 works perfect when you’re running SliceMaster. Well done WRL team!
Bringing this one back up as a new Flex owner…. I know that if I’m running WRL cat control with JTDX/WSJTX (on 2237) it logs perfectly. If I add Port#7280 (presuming enter it into the “TCP CAT TX Listener) that should allow for WRL to pull the frequency data into the contact log?
