Cat Control FlexRadio Maestro (not SmartSDR)
Hi! I can see in CAT Control that there is an option to connect SmartSDR via a CAT port. I’ve tried it, and it works. However, there is no option to connect to the radio itself when using Maestro. Are you working on a solution so that FlexRadio can be used with Maestro?
@SM6YEC I’m not familiar with the flex or maestro however there are several users that have this working as expected (maybe not with the maestro though). Here are some links to scroll through:
With all that said, we dont currently support network connected devices via the cat control app but that is something we have on the roadmap.
