Command Center: Edit Location
Hi there!
After seeing the new command center during last week’s live stream on YouTube, I just checked it out for the first time myself, and I’m loving it, thank you guys! Pretty awesome work!
While looking at it, I thought about how it could be used during my next vacation, and I immediately noticed that I couldn’t change my own location right now. I know this is early access, so there’s a lot of improvement going on. So just in case no one came up with this one yet:
We already have a list of saved locations for a user, so you could simply reuse this dialog and let us select one of an existing location, or create a new one:
@DL9PD So your location on the map comes from the default saved location in your account. So if you need to change this location, just goto your profile and then ‘my operating locations’ and then create/edit a saved location and set it as the default.
Hi,
ok, thank you Brad, good enough. Although adding a shortcut to switch the location from the command center would still be a nice feature :slight_smile:
See you on the air, 73!
