Hey WRL,
Sooner or later it will come up that the app needs to help support remote station operation.
For instance - remotehams.com or remotehamradio.com
For WRL it would be nice to have a single click to change my location to TX, NH, MN, GA or any other remote station ‘location’ for a single session.
For instance if I log into a TX remote station I would always use K0PLT as my operator ID but I would also always use TX as my location
P.S. the new WRL CAT control works great with my RCForbs lLient software when I operare remote I can instantly click on POTA spoting and the remore station changes to that frequency and WRL fills in all the details (except for my ‘location’)
This is some good info from RHR:
When in doubt…
It’s pretty straightforward: most of the time, just use your own callsign.
Because you have a U.S. license and are operating stations within the U.S., you do not need any further identification beyond your regular callsign.
What about my location?
It doesn’t matter where you are sitting – what really matters is where the RF is being emitted.
When sharing your location with other operators, you should explicitly use the location of the station you are operating. Every station has its county, state, CQ region, ITU region, and grid square listed at the top.
For example, if you are exchanging grid squares during a VHF contest, send the grid square of the station you are connected to, not the grid square of where you, the operator, are physically located.
You may choose to add a prefix or suffix to your callsign to identify the geographic region of the station you are remotely operating, but it is not required.
What NOT to do
Never identify yourself using a non-U.S. callsign.
Never identify yourself using someone else’s callsign.
Never claim to be operating from your home location instead of the remote station’s location.
73s
Peter
K0PLT
