Failure of WRL winter filed day log to count for NOTHING
I used WRL to log my Winter Field Day QSOs and then downloaded to the Winter Field Day. The Final results showed Everything I submitted was rejected. I used WRL template. I am extremely unhappy that the effort I put into WFD was totally for NOTHING. Did anyone else have the same outcome that I had with all contacts being rejected for wrong or incomplete submittal. W3BMK
Initially when I first uploaded, mine showed 0 contacts made. But after waiting a day or so I re-uploaded and it worked fine.
The file I created and uploaded to WFD was accepted with no issues. What was the error you received?
Which export did you use adif or cabrillo? I used the adif export a had no problems with it being accepted.
