FT8 spots showing up despite filter setting of CW?
Is there a way to edit a band plan so that FT8 spots in the range 7074-7077 don’t show when I have selected CW as the only mode for spots ?
Andy K3UK
@K3UK Not currently, the band and mode are set based off of frequency currently. We have plans to add some logbook settings that will allow you to do things like this though.
However with that all said, after you enter the frequency you can then change/update the mode manually before logging the contact
