just did a POTA activation and created file name KI5OLV@US-6574-08022024 which is how POTA wants it… but instead I get this below… this is not what I want to do is fixing this after every POTA activation any help would be great other stuff also but this one is problem for me… ty 73
KI5OLV_WorldRadioLeague_1722634078791.adi
Hi Phillip ![]()
You mean the logbook name is KI5OLV@US-6574-08022024 but when exporting the ADIF it is called KI5OLV_WorldRadioLeague_1722634078791 right?
Yes, that’s exactly what I mean. The file name needs to be what I put above when we Export
FYI… POTA does not require the filename to be in any special format anymore. This change happened after the update of parks. I do still keep it the same for my own personal preference though.
Mike KG2MM
Ok great I wasn’t aware of that ty 73
Ok, I will report it to the team to see if anything can be done, but in the meantime you can rename the ADIF to whatever name you want to give it.
