I intended to log via the iOS app for WFD but it was, to say the least, too cold to do so. I logged on paper and tried to record QSOs on the WRL Web form. Changing the time for each contact was neither quick nor intuitive, as was most of the entry process. I gave up and used HAMRS. Surely there’s an easier way to do this?
Hi @VA3MZD thanks for letting us know about this, I’m sure we can help!
If you use the website instead of the mobile app, it should make entry easier.
You could also try changing your logging template to the “All Fields” template so that it shows the time and date as a primary field instead of secondary field.
Does that help?
If there is anything we could change to make this easier, let us know and we will try to make the change for you ![]()
