How to Change the Log Timestamp from Handwritten Logs
Sometimes I do not have my lap top to activate a POTA park and will just use hand notes. When I get home to enter the info into WRL I seem to not be able to change the time so that it corresponds to the time I made the contact; the log book wants to put in the current time. I’ve tried to put the curser over the time but it will not allow me to change it. How do I enter this different time?
@W1CBM Hey Charles,
Below is a screen recording on how to do this. However you can download the mobile app on your phone and use the mobile app to log your contacts instead of having to log on paper (unless you just prefer to log on paper). The mobile app works without an internet/cellular connection so you’re still able to log your contacts. If you dont have internet at the park you just log the contacts and once you get back to a stable internet connection, re-open the mobile app and all your contacts and logbook will sync to the web app and the callsign lookups will happen adding all the data to the QSO records.
Pro Tip: If you use the mobile app, just create your pota activation logbook, and set the park reference number(s) before heading out tot he park so your logbook and everything is ready to go when you get there.
I hope this helps
Thanks, that was helpful. I was putting the cursor to the right of the time and hitting the delete button and it was only changing minutes. That for getting back to me.
@W1CBM of course, happy to help!
