Looking for a plain jane logging program
Can anyone here steer me in the direction of a plain ordinary “no-frills” logging program? I’m looking for something that I can use to log 2mtr/440 contacts for the time being until such a time when I will be better be able to afford a good used HF rig. I have done some research and so far all I have able to find are Contest Logging Programs. Maybe I’m missing something here. I don’t know. Any help would be greatly appreciated.
@N5LYS Gregg Good morning!
You can create a new logbook using the ‘Default WRL’ template which is pretty stripped down. This would give you the ability to log your 2m/70cm contacts without any issues. Also if you happen to be mobile in your vehicle or on your HT and making contacts you can use the mobile app using the same logbook and all your contacts will sync between the two so you keep all your contacts together. Just a thought :wink:
Great…thanks for the suggestion :smiley:…I appreciate it a lot.
73,
Gregg Thacker
De, N5LYS
If it don’t have a Steel…it ain’t REAL!!
@N5LYS Gregg, you more than welcome! Happy to help! Let us know if you need a hand with anything else or run across any issues!
K4AZE De, N5LYS…
No Problem…Will do :grinning_face:..
                                                         Gregg
                                                         N5LYS
Well, would a “scooter mobile” suffice :joy:? Litterly, I have a Retevis RT-85 Dual Band HT that I have mounted on the handle bar of a Mobility Scooter and a Comet Dual Band Antenna that’s mounted on a basket specifically designed for Mobility Scooters. It works purrdy well an I can hit a lot of the local repeaters in the area and one that is 20 some of miles away. A lot of the time when I sign on I start with This is November Five Lima Yankee Sierra “scooter mobile” monitoring :joy:. I like that…kinda has a “ring” to it :rofl:…
:joy: Whatever works i guess!!! :wink:
