I have submitted a bug report, in the event this is actually a bug. I setup LOTW integration today (8/27/25 @1045 PST), but when I check the numbers between LOTW and the WRL Analytics tab, they seem to be out of alignment.
I should have more DXCC confirmations than what WRL is listing. WRL is showing 9 confirmed, but LOTW shows 25 confirmed, with up to 65 mixed confirmations. I did perform an import to make sure my WRL account had the latest from LOTW.
@KF7LPU Currently the confirmation count is based upon the confirmations from within the WRL system.
The work currently underway with the database enhancements will give options for new features and services. The ability to recognize confirmations from outside sources is being looked at as one of the enhancements.
I know the development team are looking at this as it has been a topic of many comments,
I have DXCC (QRZ) under my previous callsign and am approaching DXCC under my current callsign (QRZ, LOTW uses all data and I Ihave 90 confirmations in it), yet inside WRL I only have 10 DXCC confirmations. Also WAS in each of my callsigns but I am at 44 inside WRL.
Not sure if this is a known issue - I imported from my LoTW account and only one DXCC, Mt. Athos, is not confirmed on WRL although it is confirmed on LoTW (four different verified QSO’s on LoTW). Maybe the SV2ASP/A callsign or the SV-A Mt. Athos DXCC designator are causing a miss of the verification?
I did try to manually fix this but couldn’t find a way to add a confirmation manually to a QSL.
I attached a screenshot of one of the Mt. Athos QSO’s that shows QSL’d and verified under the Notes field, but this one still shows as unconfirmed in the WRL Stats page.
