I’m a bit confused about how the Logbook of the World integration really works. For some background, I joined WRL a couple of weeks ago. I created a new logbook, exported all my contacts (21,000+) from my Ham Radio Deluxe logbook, and imported them into my WRL logbook. Now I’d like to connect to LoTW to check confirmations. My statistics are off all over the map, and I’m wondering if pulling down LoTW confirmations will help clean things up.
The video on the LoTW integration says once I integrate, I can import my LoTW contacts into WRL. Does that mean that the integration downloads the ADIF from LoTW and then creates net new logbook entries in WRL? If so, my logbook would double in size because nearly every contact would be double entered.
Or, does the integration just check LoTW for confirmed contact flags and then update my WRL logbook to show those contacts as now confirmed via LoTW? This is what HRD, N3FJP, and other logbooks that integrate with LoTW do.
Thanks for your help.
Ian, NV4C
WRL Member #4416
